Gasket Sealer Or NO???
Old 07-25-2012 | 03:38 PM
Default Gasket Sealer Or NO???
Just putting some things together and I am curious whether everyone uses a gasket sealer or not. I usually just bolt up things like water pump and thermostat housing with just the factory gasket.
Trying to avoid leaks and I have not really had the best of luck with using permatex
Baja226sport is offline
Old 07-25-2012 | 04:33 PM
F-2 Speedy's Avatar
on the things u mentioned ( sealer ) try Coppercoat
F-2 Speedy is online now
Old 07-25-2012 | 05:48 PM
i do a smear cote with the right stuff,no leaks.
mike tkach is offline
Old 07-26-2012 | 12:02 AM
A smear of RTV on both sides unless you know all your mating surfaces are perfect.
f_inscreenname is offline
Old 07-26-2012 | 10:19 AM
rich allen's Avatar
RTV is great for certain applications, but lately I have been using more semi permanent type sealers that dont fully harden like rtv does. Less chance for contamination during part swaps, and I like the idea of a sealer being able to conform to any retorques, shifting, etc.
rich allen is offline
Old 07-26-2012 | 10:57 AM
Ok, so what type of semi permanent sealer are you making reference to?
Old 07-26-2012 | 11:31 AM
Rookie's Avatar
Originally Posted by mike tkach
i do a smear cote with the Right Stuff,no leaks.
The Right Stuff is the Devils snot!
The Right Stuff is what you want. A little less aggressive for easier removal and what I like to use some times is Ultra Black. I have had intakes that were a pain in the A$$ to remove that were Right Stuffed, but I guess that is not a bad thing.
Rookie is offline
Old 07-26-2012 | 11:40 AM
i use permatex RTV black for the intercooler\supercharger seal (no gasket), thermostat housing, water pump crossover get merc perfect seal. works well.
nedpoole is offline
Old 07-26-2012 | 05:20 PM
Default fixx
rite stuff on intake front and back but ultra seal on gasket surface and the bolts..you only need a vary thin coat applyed with your finger..
FIXX is offline
