Velvet Drive Rebuild
Old 07-25-2012 | 04:00 PM
Default Velvet Drive Rebuild
I'm getting ready to re-assemble my VD 71 series.
I have a question, in the manual it says to check the clearances at the bottom of the clutch pack, then it tells you there are certain snap rings in various sizes to help achieve this.
The clearances in the manual are .018-.053,,,,,, now is that the clearance you're supposed to have?
Because they make shims (snap rings) that size.
I'm probably overthinking this but it could read either way IMO.
Thanks in advance.
CC230 is offline
Old 07-26-2012 | 07:03 AM
Mbam's Avatar
Offshoreonly Advertiser
That is the clearance. Try and stay at the low end of the range.
Mbam is offline
Old 07-26-2012 | 11:53 AM
Thanks Mbam!
Right now i have .044 there's a .035 snap ring but I think that would be too tight.
It didn't have one there when I took it apart so I think I might be ok.
Thanks Jody
CC230 is offline
