procharger fuel system routing
I need a little help. can someone give me the correct installation of the procharger fuel system on a 98 454 mag.
trying to diagnose a fuel pressure problem and don't have the manual to see how it was routed. contacted procharger and they said they have to mail it. so now i have to wait.
it comes from the tank into a black electric fuel pump then into the filter from there it goes under the motor to the cool fuel then into the big red regulator then tee back into the inlet of the pump.
the regulator and fuel pump i believe are aeromotive at least that what they look like
hope that makes sense
got a fuel pressure update. ran the pump into a bucket alot of fuel came out.so i reconnected everything and adjusted the regulator got the pressure set to 38 but as son as you apply the throttle it drops pressure.
i still think its the pump. i found some tiny metal particals in the bucket i ran the fuel into.
any thoughts
any thoughts
any thoughts
any thoughts
this is a 496 instalation manual if it helps with the fuel system..
http://www.cpperformance.com/instruc...charger496.pdf
My original fuel set-up on my 2000 502 mpi m-3sc procharged set-up used a a1000 aeromotive pump, it pushed it thru the stock cool fuel garbage and there was a piece that Procharger had you substitute into the cool fuel in place of the stock fuel pump, with the plastic cover on the cool fuel you couldn't see this and it looked like somehow they were still using the stock pump when they weren't, not sure how it possibly did it but it had no problem supporting 600 hp or so even with stock lines and all that cobbled up ****, I remember the adapter pieces in the cool fuel having little tiny inlet/outlet holes like 1/4 " or 5/16 ID. I tore it all out later when I decided to upgrade further and bought a small oil cooler to use as a fuel cooler and totally eliminated all the factory "cool fuel" crap. At that point I also added a second line feeding the stock rail. Later on in the quest to make even more hp I made twin rails and got rid of the stock single rail, Smitty
