Big Block Ford Mercruiser Swap ??
Planning on pulling out the Big Chevy in favor of a Big Block Ford into a Mercruiser boat with a Bravo 1.
Planning on building a 598'' A headed Carb motor with BBC exhaust flange. I still plan on running the Merc Saginaw power steering along with alternator and water pump.
Where do I start ?
Thanks guys.
Where do I start ?
Thanks guys.
Look here.
http://www.460ford.com/forum/showthread.php?t=110425
2112 is on here as well, but the best pictures I've seen are on the 460 site.
Registered User
Where do I start ?
Thanks guys.
Where do I start ?
Thanks guys.
Registered User
We are running speedmaster drives which requires a trans, so we have a top mount starter bellhousing for the FORD and bolts the trans to that. I'll have 2 sets of motor plates, that you bolt to L brackets bolted to stringers, these will be available also, we are building new. These are steel, powder coated silver. Rex marine used to have these bell housings. Call me if you like. Bob Powell 610-996-0311
