Bilge pump question >
Bilge pump question
Bilge pump question
Old 07-30-2012 | 08:57 PM
Default Bilge pump question
I finally got my boat in the water after the motor rebuild! When to stopped I noticed the bilge pump was running without any water leaving the boat. The mechanic must have bumped it off it's base and it is flopping around under the engine. The boat is a baja h2x with a 7.4 mpi. Does it just snap back on the base? Any advice on how to pit it back in its place? I burned my arm trying to fix in on the water and will regroup and try again in the morning. Any advice would be appreciated
Z06vette1 is offline
Old 07-30-2012 | 09:33 PM
Smitty's Avatar
Normally you mount the base to the bottom, then snap it in by lining up tabs and pushing down. You may have broken tabs or a cracked base. I used zip ties to hold one of mine in and it held fine for many years and a rough ride. Let us know what you find.
Smitty
Smitty is offline
Old 07-31-2012 | 10:35 AM
Wally's Avatar
Were doomed!
Unless your bilge pump has a built in float switch then it shouldnt be running even if its off the mounting base. I'd check to see if the float switch is stuck or maybe you have a short in the wiring somewhere...
-Wally
Wally is offline
Old 07-31-2012 | 04:10 PM
Thanks for the help guys, the mounting base was broken and the float was all full of crud so I replaced the pump this morning with a new unit. Only a few cuts and scrapes.... Would have been nice if they noticed it when they installed the engine I put a 1000 gph pump in hope this will do the trick.
