Replacing stringers do tool contaiminate good parts!? >
Old 07-31-2012 | 01:40 AM
Default Replacing stringers do tool contaiminate good parts!?
I cut out all the bad wood. I cut the between the bulkhead and the rear engine stringers. The bulkhead is rotten, thankfull it is seperated from the rear engine stringers by a thick layer of fiberglass, so the engine stringers are perfect, but i was worry once i finish the job will by sawzall blade have planted rot? Should I spray the stringer or put a heat lamp on it? Probably OCB but I do not want to do this job again!
cyrus77 is offline
