Engine stuck?
I have a 1990 5.7 merc that has sat for 2 years. When hand turning the crank, it will turn a full revolution one way then get stuck, then turn it back a full revolution then get stuck.
I did have the bottom leg apart to change the water pump impeller, could I have not put it back together correct or could this be a motor issue? It ran great when I shut it down last, Thanks.
I have pulled the plugs and put a little oil down each cylinder. When I crank the crank bolt with a socket it just turns one way about one full revolution then back the other way one revolution to a dead stop. I am worried if I try to start it , it may ruin something?
the best solution is to pull that head and fix it correctly but i have seen people in similar circumstance flood the guide with penetrating oil ( i like corrosion x ) and tap the top of the valve w/ a soft hammer until it moves a bit and you do that for a while and it moves and returns further and further until it frees up. i am not going to say that this is the way to REPAIR anything but it has a 50 -50 chance of working and getting you going.
the bottom line here is that unless the intake and exhaust were sealed up and the motor fogged (which i have to presume isn't the case since it already rusted a valve, ) that the bores are rusty and the other open valve seats as well... so... if the motor is a beater that you will be happy to just have it start and run, then go for it... but if the motor is some valuable piece you might want to think about a freshening up to have something good when you are done.
