mirage 23 plus help
I have an 88 baja with a bravo 1 and was running a 19 pitch quicksilver. I came across a pretty good deal on a 23 pitch mirage plus from a mid nineties baja which looks to have never been used. This prop has baja performance boats etched into the side and is different from the other prop. How can I tell if its solid hub vs rubber hub? How can I tell if its good to go on the boat? I mean it fits but has a very small gap between drive and prop and doesnt have a large internal hub that runs the length of the hub only one that is 3 inches or so. Any help appreciated
I've got a 454 that has been rebuilt to a 468 with some pretty good parts. Different heads, good sized cam, and 850 Holley carb. I think it's pushing between 450-500hp. I don't know for sure what the wot rpms would be cause I'm kinda scared to rev it too high and I've already spun one prop. I think with the 19 pitch it will rev past 5000 and that scares me so that's another reason I'm trying to drop the rpms a little and hopefully get a higher cruising speed.
^^^ Yep no shame in testing out different props...
I also have a 265 that came with a 19p. Only mine has been repowered with a 502 EFI. Food for thought, here is what mine did . With the 19p I could get 52 mph and could rev over 5000. I also got a 23p baja prop from a buddy. With it I get 56-57 mph but can only spin 44-4600 rpms depending on water/load.
