502 mpi upgrade(s) ??
I have a 97 502MPI it has 403hrs on it. I hear these motors have head gasket issues. I boat alot so wanted to freshen the motor this winter. Are there any simple or cheap upgrades to squeeze some more power out of this thing. While in the freshening process. One thing i would for sure like to have is a little bigger cam. I know i cant afford to spend a ton of money on a big engine build but i atleast want it to sound better. ALL IDEAS WELCOME. Thanks guys.
Call Bob Madera at Marine Kinetics for a cam. Your best bet would be better heads (aluminum possibly), bump compression a bit, bigger cam, and good exhaust manifolds with long risers to be able to maximize cam without reversion, and re-tune the ECM. The intake is extremely restrictive on that motor and will be the limiting factor. Should be able to add 100 hp doing the right things that way. Talk to Bob, he knows these motors. Budget will be your biggest factor and determine what if anything you can do.
Keep an eye out for some good used stainless marine exhaust. Heads will likely be your biggest expense if you go with nrmew aluminum. Can have yours reworked for alot less. I would think that $4000 should be a hell of a start
I wouldn't touch it with 403 hrs. IMO, its a waste of money, especially without at least doing a leak down test and finding an issue. About the soonest I have ever heard of somebody loosing a head gasket on a 502mpi is 550hrs. Plenty of people have 800+ hours without them ever being taken apart.
