RC Boats Anyone build one from scratch?? >
Old 08-08-2012 | 11:16 AM
Default RC Boats Anyone build one from scratch??
So in the off season, I race RC Offroad Trucks and Buggies. I have been doing so on and off since just a little guy. Anyway, lately I have been thinking about purchasing an RC boat to play around with when anchored out at our local sandbar.... But then I though I want it to be as close to my real boat as possible. So I figured, why not build the hull from scratch.... Any of you guys built an RC boat from scratch or ran across a forum where guys are building them. Just curious to see others ideas. I would like a scale version of my Velocity..
low_psi is offline
Old 08-08-2012 | 11:19 AM
I built an airboat from balsa from scratch when i was a kid but I think it was a kit. Had a little airplane motor it was loud as hell but fun.
pstorti is offline
Old 08-08-2012 | 11:41 AM
Randy Nielsen's Avatar
jrcbd.com/content.php is a pretty cool site. Lots of cool projects & people to help. Just like full size boating, how much do you eant to spend?
Randy Nielsen is offline
Old 08-08-2012 | 11:42 AM
I am thinking of building the structure in balsa, then laminating with fiberglass and gel coat.
low_psi is offline
Old 08-08-2012 | 11:44 AM
It really isn't about how much I want to spend... I have all electronics as I race RC cars so I have an abundance of servos, receivers, radios, etc. And the materials to build the boat hull from scratch can't be that much. Balsa, fiberglass, etc...
low_psi is offline
Old 08-08-2012 | 11:47 AM
My brother makes his own plugs and pops molds from them. Not rocket science but very time consuming. Be easier to find a hull and sculpt a deck to look like your Velocity. I can ask if he has a blank hull laying around if ya want.
POWERPLAY J is offline
Old 08-08-2012 | 12:08 PM
Didnt really mean it like that. If you have all the stuff & can build it yourself it wouldnt be very expensive, you might find a similar hull to what you want for a couple hundred bucks if you dont build one the running gear would be around that & a motor a few hundred. I have a 4' cat with a full mod motor that will run 80+ it is evil!!
Old 08-08-2012 | 04:09 PM
Im in the process of building a 48inch cat from plans i downloaded free. Stringers and bulkheads are made from plywood. Going to use balsa to cover it then glass it.
drozz30 is offline
Old 08-08-2012 | 04:26 PM
Default fixx
yep! a 50'' cat with twins but did not have it long enough to take pictures..some stupid mother phucker in a 32 fever went out of his way to chop it up in tiny little pieces..
FIXX is offline
Old 08-08-2012 | 07:23 PM
How thick and what type of plywood are you using?
low_psi is offline
