Go Back  Offshoreonly.com > General Discussion > Boating Safety
What mooring line? >
What mooring line?
What mooring line?
Old 08-08-2012 | 03:52 PM
Default What mooring line?
Just curious what size mooring line people are using on 30-35 ft boats? 3/8", 1/2" or what else?
inthetundra is offline
Old 08-08-2012 | 04:00 PM
for that TUG, I wouldnt use anything less than 3/4" line ..... Just kidding. you should be fine with 1/2" but 5/8' would be better.
poiuy10 is offline
Old 08-08-2012 | 05:46 PM
We have 4 25ft, 3/8in 3 15ft 3/8in, 4 30ft 1/2in and 3 25 ft 1/2in, we don't use the 1/2 in very often. The 3/8 lines are good to 4700lb (Breaking Strenght) and the 1/2 are @ 8500lb We have a 382 formula and the boat is 10500 lb dry !!!
formula 382 sr-1 is offline
Old 08-08-2012 | 07:21 PM
seafordguy's Avatar
Personally, I like the smaller ropes. It isn't like I keep the boat in the water so the most I'd ever have to deal with would be a thunderstorm that snuck up on us.
The smaller ones just seem to be more friendly.
seafordguy is online now
Old 08-08-2012 | 08:02 PM
TUG??? ROFLMAO I figure double-braided 1/2" would be more than enough for this once it does hit the water. I don't think the cleats are big enough for anything bigger anyway. Like some others I doubt it will be left in the water very often other than a night here and there. I was just curious about what others prefer.
Old 08-09-2012 | 08:49 AM
Knot 4 Me's Avatar
Only one way to go IMO...
http://www.mooringlines.com/lines.htm
I use the 5/8" on my 26' boat and I do not believe they are overkill. As for length, it like the shorter lines for tying off the stern and the longer lines for the front so I can do a spring line.
Knot 4 Me is offline
Old 08-09-2012 | 11:28 PM
I prefer 1/2" for all around use and docking but if you tie up with smaller boats (especially Crownlines) 3/8 will work.
Run 25' at the rear and 25-30' at the bow.
When rafting with boats, the extra length makes line splitting or boats pulling out safer and easier.
Docking or comming along side, length makes the difference between a catch and a second throw (which may be too late and more boat manuvering is needed).
ChargeIt is offline
Old 08-10-2012 | 10:57 AM
I use 1/2" premade high quality dock lines for tieing up to other boats and docking. I used to have 5/8" anchor line and it was overkill for a 26' boat, but it didn't get tangled up. Long story, but I ended up loosing my 5/8 anchor line. This time around I bought 1/2" and I HATE it!! It seems to get itself tangled and knotted all the time...... I am going back to 5/8" anchor line very soon.
I would go with a large of rope as your cleats will accomidate. Bigger line will never hurt maters...... If for some reason you need a tow or had to tow some one, you will thank yourself for the buying the larger diameter line.... I yanked a smaller beached boat off of an island after a storm with my 5/8" line. I wouldn't have done that with 1/2".....
low_psi is offline
Old 08-11-2012 | 08:37 AM
wantsa311's Avatar
I have a Formula 34 PC, use 5/8 lines for everything. One of my friends refers to them as "Queen Mary lines" :P
wantsa311 is offline
Old 08-11-2012 | 09:55 AM
The problem comes in if you hang out with any smaller boats, sure my massive cleats can handle it...but your average Mastercraft etc not so much.
I have been on the fence about getting bigger ones, I like them more when hanging with big boats...I suppose I should just tell a smaller boat to use their own damn lines if their cleats are too small
Captain YARRR is offline
