Fuel gauge not reading >
Old 08-08-2012 | 11:17 PM
Registered User
Default Fuel gauge not reading
Is there's gauge that just tells you how many gallons of gas used. Instead of depending on the fuel gauge. I put about 75 gallons in my tank and it still reads less than a quarter tank.
Thanks for the info
sdrockslangers is offline
Old 08-09-2012 | 01:38 AM
Bad sender or the sender needs adjusted most likely. Unless you have a 300 gallon tank
And yes you can get flowscans that tell how much fuel is used, but they are not cheap.
Griff is offline
