Tantrum Finally Ready >
Old 08-09-2012 | 06:19 PM
Default Tantrum Finally Ready
Finally have the new motor broken in and tuned on my 96 tantrum. I bought a rebuilt 454 with 0 hours of another OSO member. Motor was built with all Quality parts. No dyne numbers but should be in the low 400's. Spun a 21p rev4 to 5200 rpm's at 62.5 mph. Roughly the same number with a 21 mirage( not plus) I'm thinking a 23 mirage plus will be the best fit. Any thoughts based on my numbers.
carreraboy1 is offline
Old 08-09-2012 | 08:32 PM
Cool ! Sounds close to me, I came up with a 10% slip, but I would still try the 23. Maybe evan a 22p B1
My Addiction is offline
Old 08-10-2012 | 07:24 AM
I have a quicksilver 23 if you want to try it
carrera1 is offline
Old 08-10-2012 | 08:00 AM
A friend of mine actually has one that I am going to try out today. Are you looking to sell yours?
Old 08-10-2012 | 08:35 AM
if you need it, and it works for you, sure. It in my truck now and your pretty close to me. If not i'll stick it back with stash of test props...never know what boat we'll buy next
carrera1 is offline
Old 08-10-2012 | 09:14 AM
Remember, manners change prop to prop. try it first. my rig reacted totally different when I used a friends bravo1 28, compared to the bravo 1 28 I bought.
carrera1 is offline
Old 08-10-2012 | 06:39 PM
Ok great I'll keep you posted
Old 08-11-2012 | 09:53 PM
Confused.... Tried the 23p mirage and got the same exact reading as 21p rev4 and 21p mirage. Thinking tach may be off so I ordered a new one. What am I missing here they only time I got a different reading was with a 25 mirage. I got 4800 rpm's but got the same top end. Speed is measured with a garmin.
Old 08-12-2012 | 01:01 AM
Poker&Run's Avatar
If the 23 is labbed and the 21 is stock, you get get pretty close to the same numbers. Diameter could be diff too if the 23 was nicked and someone filed it down.
Poker&Run is offline
