Waxing bottom of boat >
Old 08-10-2012 | 06:55 PM
Default Waxing bottom of boat
I had a little time on my hands and while waxing the boat decided to crawl underneath and wax the bottom of the boat. Hard to appreciate all the work that goes into the Fountain hull design until you spend a little time under her! Anyway... my question is do you think waxing the bottom is worth any increase in performance? Wonder how long it will last... Any racers doing this? At the very least I got a good arm workout -
Wes Burmark is offline
Old 08-10-2012 | 07:17 PM
Expensive Date's Avatar
Actually its said that it slows the boat down. I have never noticed any difference though. It looks better shiny.
Expensive Date is offline
Old 08-10-2012 | 07:27 PM
Same, here - never noticed anything. Also easier to clean off lake scum. I think ambient air temperature/humidity on any given day has more effect on speed than waxing the bottom.
bob_t is offline
Old 08-10-2012 | 08:00 PM
Bob, I know you are correct on the air temperature. It's something like a 1% increase in horsepower with every 5-10 degree drop.
Well, as mentioned, I did get a great arm workout and a new appreciation for the steps and pad setup on the Fountain.
Old 08-10-2012 | 08:38 PM
i heard rainex sprayed on the bottom of the hull works pretty good. may or may not give any speed but seems to keep the scum line off a little better
88bullet is offline
Old 08-10-2012 | 09:00 PM
What he said. Rain X is the chizzz...
POWERPLAY J is offline
Old 08-10-2012 | 09:03 PM
Yes, you can see the extra work they put into getting the edges sharp and surfaces flat in the last several feet of the boat, usually from the step back to the transom, when you are laying under it for a few hours
bob_t is offline
Old 08-10-2012 | 09:17 PM
did you ever gps it and see if the rain x ever gave you any mph??
88bullet is offline
Old 08-10-2012 | 09:25 PM
No. But being in the paint/detail business I have not found a better product to keep crap off the hull.
Old 08-11-2012 | 09:03 AM
The racers generally tend to lightly sand their hulls for less drag....
verbi69 is offline
