Need help with impeller part number. >
Old 08-12-2012 | 05:51 PM
buck183's Avatar
Default Need help with impeller part number.
Lost an impeller today. The ones I ordered over the winter turned out to be wrong. I used the parts look up on mercury's site and still got the wrong ones.
The pumps are what I consider standard merc pumps for a bravo 1 application. Motors are 2000 model 350 mags.
The number on the pump housing is 46-807151.
The inside of the impeller is flat on one side to match up to the shaft. The ones they sent me are flat on two sides. This is no bueno.
Buck
buck183 is offline
Old 08-12-2012 | 07:15 PM
what part number impellor did you get? for that pump I show you should have this impellor 47-59362
compedgemarine is offline
Old 08-12-2012 | 07:54 PM
buck183's Avatar
They are at my shop. Will not be up there until tomorrow to verify. Threw them in the corner this spring after I spent all afternoon removing my pumps only to realize I had the wrong ones.
I'll look at that part number and see if I can tell by looking at it. Thank you.
Buck
buck183 is offline
Old 08-12-2012 | 08:25 PM
buck183's Avatar
I took a closer look at that number. Pretty sure that's it. Thanks again. Owe ya one.
Placed my order along with express shipping.
Buck
buck183 is offline
