Removing Paint Off of Drives
My lower units need repainted and was thinking of tackling it this winter. A sand blaster is to messy, has anyone tried a dry ice blaster or a soda blaster?
I'm about to try a soda blaster, but haven't got around to it yet.
I'm curious on opinions and feedback too.
s022mag I'll post my results when I get to it, probably won't be for a couple more weeks at least though...
Make your job easier and get soda with 10% aluminum oxide mixed in. As well as going faster, it will also provide a better tooth for the repaint and remove any corrosion. We use Armex, but other brands may have it as well. Its going to be a dusty job and I would recommend removing them and doing it away from the boat. Tenting the area effectively is crucial.
Read up on soda blasting and prep before paint. Had a friend soda blast his drives and no matter no what the painter did the paint came out matte finish. Later he found out that the drives were not prepped properly after being soda blasted.
It might just be as easy as cleaning with vinegar and water. There are a few threads on the blasting and car prep forums.
[/IMG]
[/IMG]
