502EFI Internal noise diagnosis...Listen >
Old 08-13-2012 | 02:39 PM
mkramer's Avatar
Default 502EFI Internal noise diagnosis...Listen
Ok, here's the deal......view video and send in your diagnosis. A few points to note......Motor has good push rods, bearings, rockerarms and all other mechanical parts except what's causing this noise.
*Final Note: Noise goes away when we remove the #6 spark plug wire........
H-E-L-P
http://www.youtube.com/watch?v=cTvA1...ature=youtu.be
Here it is running good without #6 plug wire.....
http://www.youtube.com/watch?v=6StcU...ature=youtu.be
mkramer is offline
Old 08-13-2012 | 03:32 PM
Steve H's Avatar
artselectricinc.com
Compression test? Does it idle smooth? It almost sound like it is popping back thru the throttle body.
Steve H is offline
Old 08-13-2012 | 03:47 PM
Is this a quiz, or do you really need help?
snapmorgan is offline
Old 08-13-2012 | 03:53 PM
mkramer's Avatar
Nope, not a quiz.....Need help
mkramer is offline
Old 08-13-2012 | 05:43 PM
SOUNDS LIKE NO. 6 WIRE IS ARCING SOME WHERE!!! LOOK FOR ARCING FROM COIL TOWER TO POST ON CAP.....kEN
big jing 2 is offline
Old 08-13-2012 | 06:11 PM
do a compression test... could be a bad valve
tunertech is offline
Old 08-13-2012 | 06:46 PM
Probably not much of any help here, but interested. Agree on the bad plug wire but sounds loud for an arc. very hollow sheet metal like and rythmic not steady. (is it just following the slight lope of the idle?) Rocker hitting valve cover?
How would a valve sound like that? would think more back fire sound if it was bad. If it was sticking and smacking the rocker arm or something it wouldn't stop just because you pulled the plug wire.
Don't shoot me here, but how about a wrist pin?
Not that you'd run it like that under load, but when it started making the noise[GOOGLEVIDEO][/GOOGLEVIDEO] was there any lack of power or anything?
Just throwing some ideas out.
Mr Maine is offline
Old 08-13-2012 | 07:04 PM
Exhaust manifold gasket leaking at the #6 cylinder would be my guess.
Griff is offline
Old 08-13-2012 | 07:46 PM
GPM
What were you doing when it started making the noise ?
GPM is offline
Old 08-13-2012 | 07:51 PM
Default Fixx
1) cyl 6 could be miss firing and causing the exhaust tio flap to bang away,,make sure theirs rubber on the flap or stichk your hand in the exhause when its running when the engineis stll cold(first starting the engine)
2) i have seen a misfire cause what they call a spark knock,,thats when the #6 cylinder is not firing on time and the cylinder prefires and causes a knocking noise...try changing the spark plug and start it,,if its still their try swapping the plug wire with the other engine..
3) broken valve spring and the valve is hitting the piston,,inspect #6 plug for color,,listen the that side of the exhaust,will sound different than the others..could be exhaust valve spring or even a bent push rod..
4) good luck!
FIXX is offline
