WANTED: HYDRAULIC steering setup for twins >
Old 08-15-2012 | 01:49 PM
Default WANTED: HYDRAULIC steering setup for twins
looking for hydraulic steering setup for twins. PM me please
overdooinit is offline
Old 08-17-2012 | 06:53 AM
Me too. Pm him first but if he has found a set up I am looking as well. Pm please
Adamcoover is offline
Old 08-17-2012 | 11:56 AM
resurrected's Avatar
If you want to piece it together I have Marine Machine Wing plates for Mercury Bravo outdrives and tie bar for twin engine hydraulic set up. This set up is extremely heavy duty with 1 5/16" diameter tie bar that is 54 3/4" center to center. This is perfect for a medium size cat with bravo drives. The tie bar can also be shortened at your local machine shop at minimal expense to fit any twin engine application. Steering rams can be attached outside or inside of the wing plates on this set up. I do not have the long studs to mount them to the bellhousings. I will take $500 and you pay actual shipping, located in ON Canada
resurrected is offline
Old 09-06-2012 | 08:32 AM
still looking for hydraulic set up for twin BRAVO's. Center mount prefered. I don't mind piece'n together either.
Old 09-06-2012 | 09:08 AM
Me as well but make sure he is given first dibs on anything ya got
Old 09-06-2012 | 09:30 AM
Veteran: Army
Default str rams
have 2 sets of marine machine rams $1000.00 per set + shipping they have knuckles on them if interested call #309-925-4620 karl
kgz3 is offline
Old 09-10-2012 | 07:59 PM
eddie's Avatar
I have a Latham set up for twins.
Attached Thumbnails WANTED: HYDRAULIC steering setup for twins-steering2.jpg   WANTED: HYDRAULIC steering setup for twins-steering.jpg   WANTED: HYDRAULIC steering setup for twins-steering3.jpg
eddie is offline
Old 09-10-2012 | 08:08 PM
I have a setup, and will get one more drive cap soviet can work for twins, pm sent
Unlimited jd is offline
