how much is this gonna cost me!!? broke again >
Old 08-16-2012 | 02:31 PM
Default how much is this gonna cost me!!? broke again
think this happened when i got caught up in a tight area on the trailer dropped it off the edge of a drive think the nose cone bottomed out on the concrete. didnt realize it happened and ive been out twice since. trim gauge quit working since it happened.
so what exactly is it thats broke. can i pull the outdrive and transom assembly and have it welded. does it need to be fixed immediatly?
dsmawd350 is offline
Old 08-16-2012 | 02:45 PM
Time for a new gimble at least.
searaycer is offline
Old 08-16-2012 | 02:53 PM
pic is hard to see but did you take a chunk out of the helmet? Thats what it looks like to me. if so you need to replace it becasue if it goes there is a chance the rest of your drive will be at the bottom of the lake.
drpete3 is offline
Old 08-16-2012 | 02:54 PM
new helmet about 900 from merc and I would expect that much in labor too.
drpete3 is offline
Old 08-16-2012 | 03:16 PM
The bell housing/helmet broke off at the hinge pin.
It's a couple hour job if you have the tools.
Remove drive. Remove 2 hinge pins. Undo bellows/shift bellows and cable. Replace with new housing. Your trim switch will work after you get this replaced.
Do not take this on the water like this. Like said above, drive might sink to bottom along with the boat. Water comes in fast when no drive shaft is in the gimbal bearing.
1BIGJIM is offline
Old 08-16-2012 | 04:44 PM
ok thanks for the help guys ill add that to the list of things to do on it haha
Old 08-16-2012 | 06:08 PM
Had one break like that on my old chaparral I had . the drive will NOT sink to the bottom because the trim cylinder's will prevent that but when the bellow pulls off which it will the boat will go to the bottom . been there !!
Jeff P31 is offline
Old 08-16-2012 | 08:37 PM
Default fixx
I M me,,,i have 2 of them that i can part with..
FIXX is offline
Old 08-19-2012 | 10:47 PM
Just got my boat back from the marina from the exact issue and it cost me 3800.00. I also replaced the gimbal ring though.
sanderps is offline
Old 08-20-2012 | 12:49 AM
Call your insurance company
Griff is offline
