All hands on throttle with the new Livorsi Triple Trim Switch for Arched Controls.
Livorsi’s new Triple Trim Switch for Arched Controls gives you even more control at your fingertips. Trim multiple drives, tabs or jack plates without taking your hands off the throttle. The triple trim knob profile is designed for comfort and switches are strategically placed to avoid an accidental switch actuation.
Livorsi Arched Controls are constructed with tough dependable materials. Heavy duty aluminum, bronze and stainless steel make up this robust design. Concealed wiring within the handle makes for a clean, well designed look. Knobs can be powder coated in your choice of Livorsi colors. The control base comes in a chrome finish or you can choose a carbon fiber or powder coated base plate for an additional charge.
Product Features
- Trim multiple drives, tabs or jack plates without taking your hands off the throttle
- Styled and designed for comfort; perfect for long boating excursions
- Switches are strategically placed to avoid accidental switch actuation
- Eliminate trim switches on the dash while freeing up more dash space
- Available for Arched Throttles only
- Designed for right hand thumb actuation
- When trimming multiple drives or tabs with 1 switch, diode kits must be added to your order (DK ,DKH2 and DKH3)
- A separate adapter plate is available to install these controls in a number of applications and boat designs
- Friction and detent can be adjusted while controls are installed in your helm
- The optional carbon fiber base plate is available in black carbon fiber or silver carbon fiber
