prop guru question >
prop guru question
prop guru question
Old 08-17-2012 | 07:22 PM
Default prop guru question
What effect will adding rake to a prop have on the attitude of the boat?
raytart is offline
Old 08-18-2012 | 01:17 AM
More bow lift.
Philm is offline
Old 08-20-2012 | 06:53 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Yes bow lift.
Too much rake when not needed can be a performance deterrent as well due to drag.
Brett
[email protected]
bbladesprops is offline
Old 08-20-2012 | 07:24 PM
I was looking for 200 more rpm, which I got from additional thinning of the blades. I also asked if anything could be done to help with a slight porpousing issue on calm water. I believe my prop guy added a bit of rake to the blades. It had a very adverse reaction. The boat seems like it is glued to the water and wants to bow steer. If I trim to the sky to lifft the nose, steering is really loose almost to a point were it's not safe. I haven't spoken to the prop guy directly to ask him what he did (he went away for a few days) I dropped the prop back at his shop and I hope to talk to him soon. I should have left well enough alone. It performed well but of course well is not alway good enough. Do you think that adding too much rake would have this effect?
(I may be mistaken about adding rake, but I think that is what was done) I think cupping would have been a better choice, but I'm not exactly an expert on prop science.
Ray
raytart is offline
Old 08-20-2012 | 07:27 PM
Who did the prop ?
billy boats is offline
Old 08-20-2012 | 07:52 PM
Smile
Bow steering issues would be the opposite of adding rake. Sounds like you went backwards.
Brett
[email protected]
Old 08-20-2012 | 08:53 PM
Brett
That's exactly what I'm thinking. I was a bit thrown by philms response to my question. It's almost like negative rake if there is such a thing.
The work was done by a reputable shop. I'd rather not say who, but he has done work for me in the past with great results. Possible a misunderstanding of what I was trying to achieve.
raytart is offline
Old 08-21-2012 | 02:10 AM
They can certainly take rake out of a prop (to a point). Most rake that has been added into a Bravo style prop is added with cupping to the trailing edge anyway.
Philm is offline
Old 08-21-2012 | 04:12 PM
I'm still waiting to speak with my guy and ask him what was done. I'll post when I hear from him.
raytart is offline
Old 08-21-2012 | 05:05 PM
Smile
We put a slight bend in the blade tips as well.
Brett
[email protected]
