Shifting a BW transmission above 1000 RPM >
Old 08-20-2012 | 07:45 PM
Default Shifting a BW transmission above 1000 RPM
I remember reading somewhere that your not supposed to shift the BW transmissions into gear above 1000 RPM's but if I set my engines to idle any lower then 1200-1400 then when I shift it into gear the RPM's drop to 500 and the engine stalls. If I blip the throttle then it stabilizes but idles at 700 in gear.
Having to blip the throttle makes it difficult to maneuver around the docks, what are my options?
Jim
502ss is offline
Old 08-20-2012 | 08:24 PM
Sounds like your carbs need some adjustment, possibly a little more base timing also.
Unlimited jd is offline
Old 08-20-2012 | 08:31 PM
Default fixx
Jim
need more of the build,,what drives prop size and style,blowers? what carbs and cfm..
FIXX is offline
Old 08-20-2012 | 08:32 PM
mine have idled at 1100 to 1200 for years with no problem. 540 blower motors with Huber 1450 trannys.
kvogt is offline
Old 08-20-2012 | 09:27 PM
Seems like a lot of clanking into gear for me.
f_inscreenname is offline
Old 08-20-2012 | 11:14 PM
BDiggity's Avatar
i have the same problem on occassion. i know its my carbs. i need to fiddle w the idle adjustment again. They seem to be finicky w/ weather conditions. Always makes for fun docking when half time im restarting engines.
BDiggity is offline
Old 08-20-2012 | 11:25 PM
Rookie's Avatar
I locked my timing out @ 35* and my engines never idled better 600RPM. And I have aggressive solid roller cams. Before I was always fiddling with the carbs they ran totally different hot/cold.
Rookie is offline
Old 08-21-2012 | 01:53 AM
Unless you've got some 800hp engines with big solid cams, there is no reason the engines shouldn't idle below 1000 rpms and have a 200-250rpm drop going into gear.
Griff is offline
Old 08-21-2012 | 03:21 PM
Thanks everyone!
I will definetly check the idle circuit next time I am out. The only reason I didn't initially is because everything was perfect last year! The only variable I changed this winter was having both trannies rebuilt. I was thinking that maybe now that their all fresh parts that they were running a bit tighter which is causing the issue!
502ss is offline
Old 08-23-2012 | 08:00 PM
Ethanol fuel does "great" things to carbs! Also little things such as acc belt dust get through the flame arresters and plug the air bleeds. I know from experience.
