Pitted Drive Clean Up >
Old 08-22-2012 | 07:51 AM
Default Pitted Drive Clean Up
Guys how are you cleaning up pitted drives? It's fresh water only and its a 1.32r alpha 1 behind a big block, not so easy to find. How can I fill in the pits and make this thing look factory nice again? Otherwise it is in pretty good shape! When I got it, the zink was so far gone, it was missing some of it's base
machloosy is offline
Old 08-22-2012 | 08:00 AM
I have the same issue - would be interested to see some answers. Coming from the outboard world I was just going to use the process they use for the installation/ feathering of nose cones - get the drive paint free and all oil and dirt removed and use marine epoxy to feather it smooth. http://www.hardin-marine.com/Instructions/620-11250.pdf
Port Monster is offline
Old 08-22-2012 | 08:05 AM
Biggus's Avatar
I've had great results with Marine Tex ,
http://www.jamestowndistributors.com...word=marinetex
Biggus is offline
Old 08-22-2012 | 09:43 AM
Sand the paint off with 80 grit and get a little smooth. Then put a nice epoxy primer on it. Fallowed by a few coats of high build 2k primer. Then sand it down smooth with like 150. You might have to reapply a couple more coats of primer to get whats left. then make sure it is sanded with at least 400 and paint with a nice urethane single stage black.
86Capri is offline
Old 08-22-2012 | 10:29 AM
Sounds like the way to go is an epoxy followed by good filler primer, followed by a good single stage urethane. Anybody have before/after pictures??
Old 08-22-2012 | 12:00 PM
just after I wish you guys could have seen before.
[IMG][/IMG]
86Capri is offline
Old 08-22-2012 | 01:20 PM
Went searching a found this pic Capri. Definitely looks better than a Merc reman. Did you use a filler? Epocy or something else?
Old 08-22-2012 | 06:18 PM
Default fixx
you want to use a product from USC called ALL METAL..its a alunimum fiber mixed with vinalester resin..make sure its fresh,,when you open the can and its hard on top or looks dryed out take it back and get a fresh one..the stuff sands real nice too..follow up with ppg dp 90 epoxy primer to seal it up then paint it with imron..
FIXX is offline
Old 08-22-2012 | 06:23 PM
just remember. don't be too rough on the orig metal. it is getting thin in the base of the pits. you go grinding away or sand blasting it, and the oil may fall out. then it'll look like a brand new housing!!!
dereknkathy is offline
Old 08-22-2012 | 07:49 PM
I just redid my bravo drive. First I sanded down to bare aluminum. Used a wire brush to clean out the big pits then hit with a etching primer. Then used Evercoat Metal Glaze as a filler. It is easy to sand and applied with a spreader where I could and used my finger in other places. Sanded back down smooth then hit with high build primer, sanded again, then hit with duplicator engine enamel. Turned out great. I will try and post a few pics or the thread where I posted pics.
low_psi is offline
