Can I use these heads?
I bought some Dart Eagle Iron BBC heads from an OSO member and discovered two of the heads have a holes leading from the exhaust runner into the head bolt cavity. The heads were unported so this was caused by corrosion. Is it okay to run these or should I be looking for some new castings?
http://i534.photobucket.com/albums/e...IMAG0271-1.jpg
about 15yrs ago i had a set of heads that iwas porting for one of my drag cars.i put a hole in the exhaust port hear where your crack is,they were not gm heads,but cast iron.my engine guy sent the head to a guy that gas welded them.he stuck the whole head in a industral oven and heated the head red.took it out and made the repair and slowly backed the heat down.i was told this was a all day deal.the patch heald.check w/your motor guys.i am sure they have some body that does this sort of repair.
They would be on the way back to who sold them to me or to the recycling bin. One or the other.
If the seller wont take them back, I think I would call in a professional for evaluation on the repair procedure and cost. Those heads (new) are only about $1800 with good valves and springs. Dont get to upside down in them.
ive ran heads like that alot but only on race car motors .had no problem.
the hole goes through the head bolt hole when porting , but if its from corrosion i would be afraid of where the next hole is going to be. hope you get your $ back.
I had a set of those heads with the same problem in one exhaust ports. My machinist opened up the head bolt hole by drilling it out and pressed a sleeve into it. Worked great! There was a small "bump" in the port from the sleeve but Imo was very minimal and it did fix the problem.
