What is the optimal rpm for a 500hp (carb 1998) >
Old 08-22-2012 | 10:21 AM
Question What is the optimal rpm for a 500hp (carb 1998)
Fooling around with props and would like to know what the target rpm is?
2Slow4me is offline
Old 08-22-2012 | 10:25 AM
97FASTech's Avatar
Veteran: Army
On the 97 HP500 WOT is 4800 - 5200rpm. Should be same.
97FASTech is offline
Old 08-22-2012 | 02:35 PM
We raced them on the rev limiter with 38 degrees total timing
Steve
smiklos@sunprint is offline
Old 08-23-2012 | 09:10 AM
Ap I guess when you have a choice of running5200 rpm with a 30 or 4900 with a 32 (in my case that is). Either prop would be ok. The other things I guess to consider would be hole shot and mid range speed (when I went from the 28 to the 30 made. Significant mid range speed improvement)
2Slow4me is offline
Old 08-23-2012 | 09:11 AM
Steve
Hi Steve
What is the rev limiter set at?
What is stock setting
Timing? (I assume mine is set to factory specs)
2Slow4me is offline
Old 08-28-2012 | 01:42 AM
5200-5300rpms for the most HP.
Rev limiter is around 5350.
Griff is offline
