Fountain hatch trouble >
Old 08-22-2012 | 08:58 PM
Default Fountain hatch trouble
Can anyone tell me how too get hatch open button engages pump but nothing happens any tips would be greatly appreciated
FOUNTAIN TURBO is offline
Old 08-23-2012 | 05:31 AM
Too Stroked's Avatar
First question: Are you getting power? (Check battery, fuses and breakers)
If you are getting power and the hatch still won't lift, most Fountains used external hinges. Simply remove the hinge pins and pull the hinge side up while somebody holds the OPEN button - assuming you now have power. Once you get the hatch open enough to reach it, disengage the pin on the end of the lift cylinder and remove the hatch.
Too Stroked is offline
Old 08-23-2012 | 08:30 AM
yes I am getting power can hear pump engage when I hit the button but nothing happens thanx for the info
Old 08-23-2012 | 10:19 AM
Just so you know, that's not a pump. The hatches lift with a screw jack.
Old 08-23-2012 | 10:42 AM
Fenderjack's Avatar
Pirate of the Chesapeake
You need to remove the pins at the back of the hatch, slide it back. That will be enough to pull the pin on the jack cylinder.
John jr
Fenderjack is offline
Old 08-23-2012 | 10:59 AM
Thanx too you guys for the info I really appreciate it the thing worked fine last week did noticed it was not smooth going down kind of shuttered just bought the boat a few weeks ago it is my first powerboat
Old 08-23-2012 | 11:00 AM
Any ideas as too why it is not working now would also be appreciated
Old 08-23-2012 | 06:00 PM
Assuming you used the trick we told you to get the hatch open, you now need to see if you have power going to the motor on the base of the jack screw.
Old 08-23-2012 | 06:10 PM
Will check that first thank you again
Old 08-24-2012 | 10:14 PM
A few years ago I had the same problem. Took the whole thing apart, cleaned everything up and put new grease on the screw. Has been working fine ever since.
badluck is offline
