Trs u-joints
Old 08-26-2012 | 07:47 AM
Unhappy Trs u-joints
Thanks to bob at marine kinetics and the guys at dart and afr I have a problem with holding my final drives together. It
Seems that the universal joint yoke - trans side - is far too delicate for the hp and torque my mouse motors are putting out.
Did anyone ever make a beefed up joint for trs/merctrans?
I don't mind breaking the yoke so much but each time it let's go I lose the gimbal housing
Konrads are the solution but not in budget right now
And yea I know the problem is my right hand!!
M
MagMark is offline
Old 08-26-2012 | 08:19 AM
Biggus's Avatar
TRS uses a Spicer 1320 u-joint, Konrad is MUCH larger with a Spicer 1350. We've still got a few inventory reduction specials if interested.
Kurt from Konrad
715-410-0735
Biggus is offline
Old 08-26-2012 | 08:40 AM
Kurt
You are still running that special?
You are torturing me!
Soon though! Just
Looking for stop gap solution
Thanks,
Mark
You have my email address
MagMark is offline
Old 08-26-2012 | 08:57 AM
Craney's Avatar
How much hp do you have??
Craney is offline
Old 08-26-2012 | 09:24 AM
509 hp 545'# tq 400 cu in
That was on dyno with heavy oil and tight motors
Now running much lighter oil and motors loosening up
Steadily making more power
MagMark is offline
Old 08-26-2012 | 11:24 AM
You sure you don't have some other problem going on? I would think a MercTrans would hand grenade LONG before the yoke shaft. Never heard of yoke shaft problems on a TRS at only 500hp. How fast you spin'n then small blocks?
picklenjim is offline
Old 08-26-2012 | 03:19 PM
Rookie's Avatar
+1
I think you have other problems. Isn't the Merc Trans yoke different than the one Biggus posted? There are a lot of TRS's running 550-600 without yoke failures. I have been running 600HP for 4yrs now.
Can you post some pics?
Rookie is offline
Old 08-26-2012 | 05:43 PM
Im running twin 545hp through bw trans with no issue....on either side....
Are u sure your alignment is correct? Seems like it could be very possible that your yoke failure is a byproduct of the gimbal failure....
commandersander is offline
Old 08-26-2012 | 11:17 PM
Yep. The one he posted is for a Borg-Warner Trans. The one for the Merc Trans has a female splined end on it and is shorter.
Old 08-28-2012 | 05:43 AM
With the bobtail mount - seems like it would have no choice but to self align
I am turning 54 to 5600
Merctran's have been updated and rebuilt
The fit of the bobtail seems tight is there vertical and horizontal adjustment in the gimbal bearings?
Thank you for your comments
MagMark is offline
