Go Back  Offshoreonly.com > Owners Forum > Powerquest
280 silencer or 29 enticer >
Old 08-27-2012 | 12:12 PM
Default 280 silencer or 29 enticer
I have been milling around these 2 boats for awhile
I have had a 2000 26 and a 1998 27
I loved the 27 with the 502 motor, had great speed and handling, I prefer the powerquest over other similar boats due to the amount of cockpit space, and the freeboard
they ride awesome.. my question has multiple parts
how does the 28 handle with the step hull
also prefer this to have a 502
also how reliable is this model with the 500hp efi motor
and is there a big difference in speed
as far as the 29, how well does this boat handle compared
to the 28 is it worth having the twins, other than reliability
i cant imagin getting more speed from the 29
just more cockpit and cabin space...
just looking for some insight between the 2 boats
not looking for alot of speed just want a decent ride with
a solid 65 mph
sea urchin is offline
Old 08-27-2012 | 01:38 PM
Knot 4 Me's Avatar
a solid 65 mph
29 with 330 HP 7.4's. Ton of them out there. Decent ride and upper 60's with this power.
Knot 4 Me is offline
Old 08-27-2012 | 03:18 PM
Josh LaFountain's Avatar
My 280 rides great. Ran 67 with the stock 502 mpi but honestly the big step on that boat makes it handle like ****. It feels dangerous at high speeds.
Josh LaFountain is offline
Old 08-27-2012 | 04:49 PM
thats 1 of the reasons i was leaning a little on th 29
side,, no step, or if i could find another 27 w/502
that was in decent shape with good colors
good colors are rare in older powerquests
Old 08-27-2012 | 05:06 PM
PROWRENCH's Avatar
You don't like teal and pink?
I had a 280 and it was fun, but they do chine walk a bit. Once you go twins you'll never turn back.
PROWRENCH is offline
Old 08-28-2012 | 08:16 AM
A 29 will chine walk up around 70 also if you are running 3 blade props... Going to 4 blade props seems to help a lot but you will lose a little top end. Try to find one with 454mags or 502mags
AJ POWERPLAY is offline
Old 08-28-2012 | 12:44 PM
Knot 4 Me's Avatar
454 MAG or 502 MAG would be the berries. Especially since those boats might actually have K-planes instead of Boat Leveler tabs on them. They are just hard to find compared to the 7.4L or 7.4MPI boats. I would still take a twin 7.4L 290 over a 280 with a 502. The ultimate 290 would have been one with twin 350HP 377 Scorpions.
Old 08-29-2012 | 04:54 PM
well, everything is always for sale for the right price! I've got a 92 with 502s (300hr range), with 280 k-planes, drives just pulled last year to replace gimble shaft and bearings, shifter lines, boots, starboard bell housing and coupler, tab censors.....actually I had about $9K worth of work in maintenance and preventative maintenance done. Yes, 90's colors, but no pink Don't have to sell, but since someone is looking I'd take $28K for her.
http://youtu.be/etpcNAtSk28
Jplanes is offline
Old 09-05-2012 | 11:39 PM
dockrocker's Avatar
I've had both, a 1999 280 with a 502 and a 1996 290 with 454 MPI's (I want to say 310? each). 280 would run 65 mph on the top end, might squeak another 1-2 mph out with no gas and a nice chop. It would lightly chine walk if I had it really trimmed out, a bit of tab and it was solid. Big cockpit and maintenance with the single was the cat's azz.
The 290 felt much, much bigger and heavier - real wave crusher. It was much more tail-heavy than the 280 and maintenance was a serious pain in the ass with the engines stuffed up against the back of the bench; PQ definitely did not have a better idea there. Again the huge cockpit and big cabin. The 290 would run in the 70 mph range, so a bit faster than the 280.
If I had to choose one, I would probably go with the 280 just because I can't afford to pay someone to do the maintenance that is such a beeyotch on the Enticer. That being said, if I could find one with Mags or 502's and real K-planes, that might tip the scales the other way. In your case, I'm not sure the size increase - 280 is pretty close to the 270 in size - would be enough of an "upgrade."
dockrocker is offline
Old 09-07-2012 | 09:17 AM
True. The 280 is really only 27'7".
