No SPARK 454 mag
Old 08-27-2012 | 04:54 PM
Default No SPARK 454 mag
I just repowered my 81 wellcraft with a 454 mag.
I have NO SPARK! I wired the ignition to this drawing
http://www.boatfix.com/merc/Servmanl/16/16F4R2.PDF
and have followed this troubleshooting procedure.
http://www.boatfix.com/merc/Bullet/83/83_24.pdf
I have 12 V at the dist and coil, when I trigger the coil by grounding the white and green wire it still doesn't spark. I even tried another coil.
This says it is the Thunderbolt module is this possible? it was bought used from craigslist but was SUPPOSED to work.
The guy at the dealer says he NEVER sells ignition modules only the trigger units in the dist.
HELP!!!!
schurgervt is offline
Old 08-27-2012 | 05:37 PM
I would go with what the manual says. Before buying anything I would double check the wiring and make sure the kill switch (if it has one) is not pulled.
Good luck
250 sport is offline
Old 08-27-2012 | 07:07 PM
Make sure the white/red and white/green wires are in the correct place on the dist. Also make sure your gray tach wire is not grounded.
Unlimited jd is offline
Old 08-27-2012 | 07:18 PM
Originally Posted by lil red
make sure the white/red and white/green wires are in the correct place on the dist. Also make sure your gray tach wire is not grounded.
x10
commandersander is offline
Old 08-28-2012 | 07:32 PM
The module case/bracket must also be grounded.
Griff is offline
Old 08-29-2012 | 07:10 AM
I have thunder bolt IV ignition and mine quit sparking. Found out my tach was bad and shorting out the ignition. Replaced tach and works great
220 baja sport is offline
Old 08-29-2012 | 08:24 AM
HELP!!!!
the flow sheet is straight foreward,if it is determined that the module is bad,replace it with a NEW one,remember,anything that is electrical can fail,i have had to replace modules before,despite what the parts guy said,they can go bad.
mike tkach is offline
Old 08-29-2012 | 08:27 AM
what power did the boat have before the repower?
Old 08-29-2012 | 09:11 AM
maybe a problem with the throttle not being in neutrals when starting. Starter solenoids bad. You get any clicking or anything just no spark.
soldier4402 is offline
Old 08-29-2012 | 11:38 AM
If the module case is not grounded, the flow chart will show that the module is bad, when in fact it is just not grounded.
Griff is offline
