Go Back  Offshoreonly.com > Owners Forum > Awesome
Hop after 80 >
Hop after 80
Hop after 80
Old 09-01-2012 | 07:59 AM
Default Hop after 80
Chris cat hop after 80. Sometimes
it dosnt do it but allmost allways it will.
It still hop at 100.
Anyone know, does tunnel tab eliminate that hop ?
shootitup is offline
Old 09-01-2012 | 09:34 PM
gary cook's Avatar
Racer
Racer
Default hop
Does it do it in calm water more than rough.
yes a tunnel tab will help
straight shafts are worse than out drives but when you get the x high they will all hop and they will hop in calm water worse
gary cook is offline
Old 09-02-2012 | 02:20 AM
More in calm water.
Have try many trim positions and different water condition
and it will hop allmost allways more or less.
Need to add tunnel tab.
Tab adjustment..
Should tab adjust in place before rising speed.
If it still hop put tab little more down
and try to rise speed again ..
or
can it adjust while running (when it start hop putting tab
down as much that hop stops ..)?
Thanks.
Old 09-02-2012 | 08:18 AM
Fenderjack's Avatar
Pirate of the Chesapeake
How about putting some drive spacers on and trying it.JOHN SR
Fenderjack is offline
Old 09-02-2012 | 01:14 PM
I suppose you mean spacers for stern drives..
Boat has arneson Asd8 surface drives.
Old 09-02-2012 | 03:43 PM
what props? turning in or out?
MrSneakAttack is offline
Old 09-03-2012 | 08:55 AM
16.5x33 4blade cleavers turning out.
Old 09-03-2012 | 09:39 AM
ok....i believe 5 blades turning in with some cup will help the hop but not stop it....that will not be your fastest props but help with the hop......what setups have tried?? thanks
Old 09-03-2012 | 10:29 AM
I've never been in a cat that didn't hop... also be very careful with a tunnel tab! If you haven't ran a boat with one and it is in the wrong position when you turn it could result in you being more like a helicopter than a boat... just saying!
gofastlvr is offline
Old 09-03-2012 | 11:59 AM
Havent any prob stock, those 4 blades are what we have.
Tested setups are different trim positions and different water conditions.
Looks like when drives are more down (little or none roostertail) the hop
Is smaller. When hop starts it cannot stop.
