Respirator question
I'm going do be painting a small boat (dinghy) using Interlux Perfection (2 part paint). It will be the first time I'm spraying-so if it isn't perfect-thats OK. The question I have is: What kind of respirator to wear? If money was no object, an air fed-full face respirator would be ideal. Since this is such a small job, can I use a canister type repirator and still be safe? Are there any specific models that I should consider? As always, thanks for your responses!
for a job this small if well ventilated you can use the 3M half mask charcoal filter disposable masks. There like twenty five or thirty bucks at any paint supply store. Harbor freight has some from Gerson thet are decent to.
08 OPA High Points Champion
I use a dustmask and a snotrag
Just joking, dont do that!!!!
The first few paintjobs I did on cars, I didnt realize how bad the stuff was, and did something of that sort, probably pay for it later in life. I still paint small areas outside without a mask occasionally, but best to just get one of the harbor freight one, and play it safe. FYI, since this is your first time spraying, and may not want to invest a lot in a gun, the HF guns are decent also. I used interlux perfection on my boat, and also a few fiends boats and like it, but mine is also clearcoated.
hey just a side note about respirators. Storage is pretty important for how they perform. Typically they are good for maybe eight or ten hours of use. When you buy one you will notice it is in a resealable package. For proper storage after use place the mask in this bag and zip it closed (we use to also use coffee cans). Now this is important, make sure you remove the fuzzy pre filter and store these OUTSIDE the bag. If these are left on air continues to circulate within the bag and the contaminates on the re filters will ruin the cartridges.
I shot a car like this once in a pinch... I think I killed half my brain - my arms were actually tingly I had absorbed so much solvent. Not a good idea...
A disposable mask like GlassDave recommended works great for one jobers (that was the route I went on the next go-around).
