what starter for larger cubic inch? >
Old 09-16-2012 | 11:30 AM
Default what starter for larger cubic inch?
I have a merc hp500 starter got it hot, had it rebuilt at a local shop lasted 8 bumps of the key and blew the drive. I heard they probably use chinese parts. I have the big teage pan on my 572 so starter change is not easy.
what starters are you guys running?
I found this:
http://www.cpperformance.com/p-13381...r-sbc-bbc.aspx
zeke is offline
Old 09-16-2012 | 04:06 PM
GPM
Tilton, http://www.summitracing.com/parts/TIL-54-40001/
GPM is offline
Old 09-16-2012 | 05:04 PM
the other issue i just realized while searching is im staggered bolt pattern.
zeke is offline
Old 09-16-2012 | 05:21 PM
GPM
Tilton makes both
GPM is offline
Old 09-16-2012 | 07:39 PM
Panther's Avatar
Frank's Marine Service
Powermaster
http://www.powermastermotorsports.com/
Panther is offline
Old 09-16-2012 | 10:23 PM
Default fixx
Originally Posted by Panther
+1
got one in my donzi for the past 12 years..i have about 6 junk tilton starters i can send you if you think you could mak one from the 6 i took out of the race car a few seasons ago..
i believe your block should have both style bolt patterns..
FIXX is offline
Old 09-16-2012 | 11:11 PM
Default check out Db Electric
I run a mini from Db Electric from ebay on my motor because of the kick out in my pan. I was concerned about the parts in it...mainly weather it had steel gears in it or not. So I emailed the owner of Db and he promptly responded that it does use steel gears. Which sold me on the starter. Very reasonable at $105.00 also. Works great!
mustangmark is offline
Old 09-17-2012 | 09:45 AM
zt260's Avatar
I replaced my merc starter with a powermaster 2 years ago. Spins a 582ci quite fast. And my engine isn't the easiest to start.
http://www.powermastermotorsports.com/250_ft__lbs_.html
zt260 is offline
Old 09-17-2012 | 10:27 AM
My Tilton starter would not work with the oil pan I had on my sbc race car. This starter cleared the pan and headers and has great cranking power.
http://www.msdignition.com/Products/...red_Mount.aspx
Shah Mat is offline
Old 09-17-2012 | 10:37 AM
I bought one of their starters after a buddy installed one on his boat. Then last summer he had his DB starter go out on him. The thing would work fine while bench testing it, but would not kick the bendix when on the boat. He installed a Merc starter and all was well.
Then this summer my DB starter began making a grinding sound. Found out that the cheap Chinese bolts they sent me had bent. Installed a set of Grade 8 GM bolts, but was still getting grinding noises. Replaced DB starter with a Merc starter, and problem was eliminated.
I know many are running these without problems, but this was my experience with them. And as you well know, starters are not a lot of fun to replace when you are out on the lake!
Budman II is offline
