Go Back  Offshoreonly.com > Owners Forum > Donzi
what GPS do you have? >
Old 09-19-2012 | 10:20 PM
mspdoc's Avatar
Exclamation what GPS do you have?
I have a 26ZX. I want a gps. What did you buy and how did you mount it. Did anybody do an "in-dash installlation" ?
mspdoc is offline
Old 09-20-2012 | 08:10 AM
I did a Northstar, the lower end units. I got the one with the built in GPS. The reason I went with it is the smartcraft capability although I haven't fully wired the smartcraft up to it yet. project to be for now.
It works fine, I put it on the right side of the dash above the trim switches/throttles. There is really no good spot for one.
If I ever re-do it all I'd do a new dash panel and set the biggest screen(s) I could in the dash with smartcraft gauges.
VetteLT193 is offline
Old 09-20-2012 | 08:21 AM
http://marinedirectory.ybw.com/Marin...rinerc435i.jpg
Raymarine 435
5" screen
get the biggest one you can afford, small ones are worthless IMHO
HTRDLNCN is offline
Old 09-20-2012 | 05:06 PM
I have a Livorsi gps gauge. It looks cool and matches the rest of my gauges; however it is the most “generous” of the gps units I have used to check speeds. After some input from others I barrowed a hand held gps, used the unit out of my truck and the I phone app. Four different units gave me four different speeds
Beachbum28 is offline
Old 09-20-2012 | 08:05 PM
Installed the Garmin 740S which turned out to be a great unit and most importantly I was able to get powdercoat bezel from Livorsi to match my other gauges. It's also large enough that it works great to display my virtual gauges (also installed Merc Monitor to convert digital buss engine info to display on Garmin)
Check out the install at: https://picasaweb.google.com/1159749.../ActiveThunder
bonesmalon is offline
Old 09-20-2012 | 09:30 PM
Sorry for the post, I was out in left field for that one!
Old 10-18-2012 | 02:15 PM
I have a 740S also with a thru hull transducer, and XM, mounted on the dash behind the winsheild on my 00 ZX28. I love it, works great on XM plus we have the weather and in the gulf you need it.
ROADTOYS is offline
Old 10-18-2012 | 09:41 PM
romie's Avatar
Had a Garmin 740s, traded with boat. i now have a Lowrance 113x. Wish i had the 740
romie is offline
