Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
wax or no wax for sanding mixture >
Old 09-20-2012 | 06:44 AM
Default wax or no wax for sanding mixture
I have some 3m glass bubbles to mix in my resin for making a mixture that I can sand. Should I also mix in some wax?
FBRONCO is offline
Old 09-20-2012 | 07:14 AM
glassdave's Avatar
Neno the mind boggler
You can but i have never really found it all that necessary when using fillers. If anything you could just brush on a coat of waxed resin at the end.
08 OPA High Points Champion
glassdave is offline
