Rear Mount Counter Clockwise Starters >
Old 09-22-2012 | 06:58 PM
CcanDo's Avatar
Default Rear Mount Counter Clockwise Starters
New Engines/New Starters, we had checked off on those parts. However, one of the first two failed immediately. Another new starter was installed and has worked as expected. That is, except for cranking RPM, which was slower than either of the two new original starters.
Subject to research, it was decided to up-grade to a more expensive starter believed to be an improvement. However, we find that starter gear to NOT be "spiral" machine cut. The gear is machined to a point, equal cut machined, each side of the tooth. Therefore, though the tooth/shaft is driven in by a very strong solenoid, into the flywheel ring gear. The problem occurs when the pointed started gear "centers" on the flywheel gear. The starter gear then spins/grinds because of not being engaged.
The first set was part number 808011-A4, the second set was 808011-A05 (FYI, 808011-A05 has nylon reduction gears. Perhaps the first backfire will toast those gears)
Back at the drawing board, we are looking for a 3 +/- HP, reduction starter with a spiral cut gear......Suggestions ???
CcanDo is offline
Old 09-22-2012 | 09:07 PM
Default Fixx
Originally Posted by ccando
new engines/new starters, we had checked off on those parts. However, one of the first two failed immediately. Another new starter was installed and has worked as expected. That is, except for cranking rpm, which was slower than either of the two new original starters.
Subject to research, it was decided to up-grade to a more expensive starter believed to be an improvement. However, we find that starter gear to not be "spiral" machine cut. The gear is machined to a point, equal cut machined, each side of the tooth. Therefore, though the tooth/shaft is driven in by a very strong solenoid, into the flywheel ring gear. The problem occurs when the pointed started gear "centers" on the flywheel gear. The starter gear then spins/grinds because of not being engaged.
The first set was part number 808011-a4, the second set was 808011-a05 (fyi, 808011-a05 has nylon reduction gears. Perhaps the first backfire will toast those gears)
back at the drawing board, we are looking for a 3 +/- hp, reduction starter with a spiral cut gear......suggestions ???
did you install a race mount between the transmission and block? If so then you need to machine the bell housing's..need to take off .250'' so the starter engauges all the way..
FIXX is offline
Old 09-23-2012 | 06:00 AM
Tiltons crank, or the Merc. is a dependable piece at a lower price. Tilton cranks my 604's like toys the Merc slower but they are pretty durable and half as expensive.
SkiDoc is offline
Old 09-23-2012 | 10:52 AM
CcanDo's Avatar
Tilton's HAD been overlooked, though we now believe Tilton has the spiral cut gear. Also, the spec. looks like a good option. And, Tilton is thought to be a quality product. The Mercury is thought to be those parts numbers listed above.
SkiDoc, do you know/have the parts numbers for your Tilton's ??? Surfing their web-site pictures, several models are shown, none of which is exactly familiar.
MrFixxall, there is a race plate between the bell housing and engine block. The bell housing is steel, the aperture is round and the starter body is a slip fit. The bell housing was relieved the .250" . The flywheel/flexplate was also dialed indicator set to <.010 and dowel staked. The starters were then installed and tested before the engines were installed.
Ironically, the Merc numbers shown , never once failed to engage. Only one 808011-A4 failed premature and the 808011-A05 is slower. However, both numbers appear to have spiral cut gears. For other applications, either of those Merc. numbers should work fine.
IMHO, these engines prefer to be spun at Max. RPM untill the dry sump pumps have oil pressure. Then, while spinning, add ignition and the engines are running. The usual spin, throttle pump, spin to start doesn't seem to work well or in theory safe. Safe being relative to flooding or back-fire. (soaking)
CcanDo is offline
Old 09-24-2012 | 02:29 PM
Cat,
We use the standard Tilton rear mount marine starter. For low compression, this is all you need. We never have any issues but sent them back once in 15 yrs to be checked/rebuilt. I used to work with Stanley Reyes , Tilton Engineering (805) 688-2353); he was very helpful.
Ben
BenPerfected is offline
Old 09-24-2012 | 03:00 PM
CcanDo's Avatar
Ben,
I have a call into Kirk Skafuel, Mr.Reyes, replacement. Thanks for the support....Will advise as more is known.
Thanks !
CcanDo is offline
Old 09-24-2012 | 03:50 PM
CcanDo's Avatar
Originally Posted by CcanDo
Ben,
Thanks !
The bad news, not only is Mr. Reyes gone, so is Tilton's starter, for this application. Mr. Skafuel stated the market was only 5-6/yr., they discontinued rear, top mount, CCW Marine starters, 6 months ago.
The question was asked about Summitt Racing showing their subject starters. The answer was; Summitt hasn't updated their web, sorry !
CcanDo is offline
Old 09-24-2012 | 06:59 PM
Cat,
The Tilton 454 type rear mount reverse rotation starters show as "in stock" at Jegs. Since when you give up so easy?
Ben
5 Products Results per Page: 12 30 60 90 Most Relevant Brand (A-Z) Brand (Z-A) Price Low to High Price High to Low Most Popular
Tilton 54-11254
Tilton MARINE STARTER REV ROT
Item# 454-54-11254
Ships 10/04/12
Only $456.99
More Info
Tilton 54-21254
Tilton MERCRUISER MARINE STARTER
Item# 454-54-21254
Ships 10/04/12
Only $547.99
More Info
Tilton 54-21214
Tilton 460 REVERSE STARTER
Item# 454-54-21214
Ships 10/04/12
Only $534.99
More Info
Tilton 54-10201
Tilton CHEV MARINE STANDARD ROT
Item# 454-54-10201
Ships 10/04/12
Only $404.99
More Info
Tilton 54-10211
PONTIAC 4 CYL 142T MARINE
Item# 454-54-10211
Ships 10/04/12
Only $412.99
More Info
Top
Old 09-24-2012 | 07:21 PM
CcanDo's Avatar
Smile
Originally Posted by BenPerfected
Cat,
Ben
Tilton 54-11254
Item# 454-54-11254
Ships 10/04/12
Only $456.99
More Info
Tilton 54-21254
Item# 454-54-21254
Ships 10/04/12
Only $547.99
More Info
Tilton 54-21214
Item# 454-54-21214
Ships 10/04/12
Only $534.99
More Info
Tilton 54-10201
Item# 454-54-10201
Ships 10/04/12
Only $404.99
More Info
Tilton 54-10211
Item# 454-54-10211
Ships 10/04/12
Only $412.99
More Info
Top
Ben,
Thank you very much, we will try that !
Look, when you get to be my age, you can give up also. Till then, back to work. LoL.... I'm sure glad you found these, we were working on a new pull rope design.
Subject to weather, would you be available to go to Texoma, Friday or this week-end ? Scott is the Hi-Port manager, whom may arrange for a facimily of a chase boat, or Leon may be an option.
CcanDo is offline
Old 09-24-2012 | 07:31 PM
Default fixx
Ben,
Hey,,we switched to 16volt battery in the race car,,man did that thing wing the starter over..just a thought..
FIXX is offline
