Converting auto engine to marine >
Old 09-23-2012 | 06:51 PM
Default Converting auto engine to marine
What all needs to be changed to convert auto motor to marine
notfastenuf is offline
Old 09-23-2012 | 10:34 PM
Brass f\Freeze Plugs, Stainless Steel Head Gaskets, Marine Water Pump - (has brass impeller), and Water Cooled Exhaust Manifolds I believe are the main parts, if you truly want a good marine motor replace the exhaust valves with inconel
Cliff
cliff_m_b is offline
Old 09-23-2012 | 11:05 PM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
You'll need a cam change and depending which engine you have maybe more to make it live in a marine application .
the deep is offline
Old 09-23-2012 | 11:16 PM
I addition to all the GOOD answers above...a marine starter, distributor and alternator. The distributor for a car has a different advance curve than that of a boat and the starter as well as the alternator should be USCG approved for spark resistance plus the fact that they are designed to be used in a severe marine environment.
sprink58 is offline
Old 09-24-2012 | 07:41 AM
Thanks for all the info u guys are alot of help
Old 09-24-2012 | 07:45 AM
Do the auto part store carry some of this or just better buying from a boat store any suggestions
Old 09-24-2012 | 08:12 AM
Oreilly can get stuff from sierra marine, and Wilson (starters and alternators) that should cover most everything you need. id it a common engine? American V8?
professor_speed is offline
Old 09-24-2012 | 09:44 AM
Napa also has some of the parts. What engine are you converting?
1987pachanga22 is offline
Old 09-24-2012 | 10:24 AM
Would be building a Chevy 454 possibly
Old 09-24-2012 | 12:12 PM
Marine engines and car engines are different internally . All if the clearances are different for marine application. Rod and main bearing clearance is larger for marine use. Also piston to wall and ring end gap are different . It makes a big difference if you want an engine to live in a marine application .
billy boats is offline
