Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
gel coat bottom but no wetsanding or buffing >
Old 09-23-2012 | 08:29 PM
Default gel coat bottom but no wetsanding or buffing
for the performance aspect of going fast would you be slowing the boat down if when someone sprayed gel coat they never wet sanded it or buffed it? on the bottom of the boat that is
mookster is offline
Old 09-24-2012 | 08:05 AM
mrv8outboard's Avatar
coolrunning racing
Smooth is fast, but sanded is faster.
mrv8outboard is offline
Old 09-24-2012 | 08:35 AM
glassdave's Avatar
Neno the mind boggler
yep, we tried 220 on the bottom of the batboats with good results. SOB to keep clean though.
As for the original question you could probably get away with a gel/Duratech finish but it would still be pretty rough. Not sure why you would want to go the effort of gel coating the bottom of a boat but only go half way through the process.
08 OPA High Points Champion
glassdave is offline
Old 09-24-2012 | 11:42 AM
jbraun2828's Avatar
Dave, what's a ballpark price on re-gelling the whole bottom of a 31ft boat? Thanks for any info. Jason
jbraun2828 is offline
Old 09-24-2012 | 03:04 PM
glassdave's Avatar
pending condition of the existing running surface you could be anywhere from six to ten thousand. Its an ambitious and arduous task to say the least.
Old 09-24-2012 | 04:12 PM
jbraun2828's Avatar
Thanks Dave, more than I thought as usual. Sorry for the hijack
