Vortec small block folks... what are you using for plugs? >
Old 07-11-2002 | 09:36 PM
TomZ's Avatar
Default Vortec small block folks... what are you using for plugs?
I'm goign to stock up on some plugs and was wondering about what some of you were using, especially heat-range-wise. I'm using a factory GM plug for auto applications. The heat range is probably more than too hot for the application and running a cooler plug might help fight off detonation (I'm still tuning and would like to run a tad more timing if I can squeeze it out safely).
Thanks!
TomZ is offline
Old 07-11-2002 | 09:43 PM
traviss's Avatar
If i remember right mine are just auto AC R43LTS... they changed the number on that to something new. can't remeber it but the auto store will tell you
traviss is offline
handfulz28
10-15-2006 02:25 PM
chriscraft240
4
08-28-2003 01:17 PM
BAD-HABIT
2
03-26-2002 11:44 PM
BAD-HABIT
1
03-22-2002 05:23 PM
