Need some 502's >
Need some 502's
Need some 502's
Old 09-27-2012 | 09:45 AM
Default Need some 502's
Hey guys,
I need a new set of 502's and was wondering if anyone knows where I can get some from.
The 502's I have are gen v and i am looking for an engine that will slip in and connect to the fuel pump, fuel injector, wiring etc..
Any help would be much appreciated.
Thx!
intimid8 is offline
Old 09-27-2012 | 11:39 AM
F-2 Speedy's Avatar
I may have two, debating on selling them complete or useing them to build 540's, I guess it comes down to what I can get out of them.
they are 2000 MPI model 502's 415 HP
PM me if ur interested
F-2 Speedy is offline
Old 09-27-2012 | 03:52 PM
Default fixx
swap plus cash on his end and build his..
FIXX is offline
Old 09-27-2012 | 07:03 PM
CPPerformance's Avatar
Here is what new ones sell for http://www.cpperformance.com/p-13691...ong-block.aspx
CPPerformance is offline
Old 09-27-2012 | 07:26 PM
F-2 Speedy's Avatar
thats deff. a possibility, have'nt heard from him other than he's interested. He has'nt posted that he has anything to trade
Old 09-28-2012 | 02:12 AM
Thanks, but I was looking for something with less hours..
intimid8 is offline
Old 09-28-2012 | 07:21 AM
http://www.1800runsnew.com/NLM/newbase-NLM.html
Great people to work with. Most all new GEN VI come with a fuel pump boss. There is no fuel pump lobe on the cam to run them.
I purchased 2 brand new and took them apart. I had RMBUILDER Bob Mandra grind cams for me. They all come with fuel pump lobes so I did not have to run electric.
Everything you have on a Gen V will bolt up.
Good luck
Exact same engine as CPPERFORMANCE sells.
1BIGJIM is offline
Old 09-28-2012 | 10:15 AM
Thanks guys! Where i live its just so hard to find someone that can actually work on these motors.
I know this sounds a bit newbie, but if i get a long block 502, what will i need to pull of my old motor and connect to the new one?
Flywheel, pully's belts?
Fuel injector?
Water pump?
I hope the list isnt too long otherwise im going to need to fly one of you out here to help me on it!
intimid8 is offline
Old 10-29-2013 | 11:18 AM
Default 1800 runs new engine 4600 rpm
I bought a 1800 runs new 502 engine but it has less power than the other motor a merc 502 I called they said its the same but its not the same,It runs 200 less rpm .I saw this online basic power sold at one time this 502 a 4600 rpm 502.BASE MARINE ENGINES
GM V8 8.2 L
502 CID
425 Horsepower V8 Marine Base Engine
Displacement 8.2L (502 cid)
Cylinders V8
Propshaft HP 425 (317 kw)
Operating RPM 4300-4600 rpm
Bore 4.47 in.
Stroke 4.00 in.
Compression 8.75:1
Engine Rotation Left & Right Hand
requires Adobe® Acrobat®
fastech271 is offline
