X dimention on straight v >
Old 09-27-2012 | 08:32 PM
T-Mone's Avatar
T-Mone
Default X dimention on straight v
Guys need some input. I have a 28ft conventional v. Boat will have a single big block. Not sure where to set x. I'm getting mix answers. Some say prop 2-21/2 below bottom an some say 3 1/2-4 below. The hull is the cig mold.
Thanks ron
T-Mone is offline
Old 09-27-2012 | 08:54 PM
Thanks ron
18-18.5 19-19.5 with standoff box
smiklos@sunprint is offline
Old 09-27-2012 | 09:08 PM
IRONMAN's Avatar
what drive? if it's a std. length bravo with 500 -700 hp than 17" would be a good start. I guess the question is what was the X and shaft depth before the re rig?
IRONMAN is offline
Old 09-27-2012 | 09:11 PM
T-Mone's Avatar
T-Mone
The boat had outboards on a bracket. So transom has never been cut. I'm running a bravo standard hight w a 540 675hp
T-Mone is offline
Old 09-28-2012 | 12:41 AM
For reference, 28 Panteras are set at 17-17.5 and that puts the propshaft about 4-4.5" below the bottom
Griff is offline
Old 09-28-2012 | 05:47 AM
you can get spacers to put a bravo deeper. so i would consider going a little higher. start at the top and make sure everything fits under the hatch first.
dereknkathy is offline
Old 09-28-2012 | 07:14 AM
T-Mone's Avatar
T-Mone
ok thanks for imput. gonna cut hole today. im gonna do 17 3/4 should be safe at that. when i did my carrera i put prop 2 1/2 below an if i ran a 4 blade no diffuser ring it was a ***** to plane off.
T-Mone is offline
Old 09-28-2012 | 08:58 AM
I wouldn't go higher than 17" and check the bottom see how much rocker or hook it has. If it has none go 16" to minimize porpoise.
Unlimited jd is offline
