Thread sealer with Oil
I have my oil temp gauge mounted in the rmote oil filter bracket. Not the best place, but it was after the motor was rigged. It weeps oil, ever so slightly. What is the best thread sealant that will work against hot oil and pressure. Teflon did nothing, I tried "red" gasket sealant. What would you guys suggest?
Thanx
Thanx
Loc - Tite makes a thread sealent just for sending units it will allow the thread ground to work with the unit. As far as how it works on sealing I'm not sure. Isn't that a pipe thread? should seal without too much trouble I'd make sure you are using the right style threads or check for something crossed. Most likely you allready did that but never hurts to ask
I have Steps & Bubbles!
I use Blue blocker lquid thread sealer in a can from Home Depot.When I use it I allways make sure that the tip and the first two threads are cleaned off(use my finger) so that none of sealer works it's way forward and goes in to the port and have had no trouble with the sender not grounding or even a leak.The biggest trouble I think is overtighting it does not take a 16 inch braker bar to put in taperd thread fittings,maybe instead of saying we need to tighten them use the word snug
Loctite 542 or 569, hydraulic thread sealant. Looks a lot like 271 (red), but seems to work even if there is oil on the threads. In a pinch I have just used 271, but the threads on both parts have to be clean. The only thing I have found is that it can sometimes be a problem if you need to "tweak" the threads after the loctite has set, you are breaking the seal.
I thought all senders that require grounding are tapered so no sealants that diminish the ground signal have to be used? I don`t use anything on any of my senders and have no leaks.
Might be time for a new sender
