How do you clean boat cover?
Brother in-law just asked me if you can clean a boat cover and if so do you just use soap and water. I tried doing a search but the search isn't working for me right now.
soap water and a brush but if you have a normal cover that you roll up you have to keep it clean because when you roll up a dirty cover you put all that crap that was on the outside on the inside and when you go to put it on all that crap ends up on the hull and interior.
Brett
Brett
For my cockpit cover, I have a "special" wood fence that I hang mine on and hose it off, let it air dry, turn it over and repeat.
No soap or scrubbing needed. Every once in a while if I have Sea Gull S#&% on it I'll hose it good and use a finger to rub the white spot. A rag or brush might be a better choice but I'm always in too much of a hurry to go fetch the stuff.
My boat lives indoors so the cover dosen't get too dirty, but I do tow with it and use it as a mooring cover.
Like I said though, my cover is just getting dirt on it and hosing it gets it clean.
i take it off the boat,spread it out in the lawn,,take some dawn dish soap and put some in one of those pump up sprayer and add water,,spray it all over the cover and let it soak,then i brush it with a floor push broom,then i rince it off with a low psi electric pressure washer..
Thanks for the info. He said it looks like maybe mold is trying to form and wondered what the best way was. I was thinking soap and water but told him I'd check what others thought on here.
If you've got mold issues, you may want to try a solution of Spray Nine or some other cleaner that will kill the mold spores. A stiff scrub brush will be a must. Wash both sides, rinse super-well, and look into a mold-killer like Kanberra Gel to put in the boat while it's covered.
My red boat cover WAS dirty and HAD black mold on it
I pressure washed my driveway to have a clean surface to place boat cover.I put dirty side down wet it with water hose and laundry detergent then pressure wash (3000 psi washer) turn over pressure wash 2nd. side. It removed ALL the mold and most all the dirt, three 1/2 in. diameter spots remain (wine stains?).With no visible signs of damage to boat cover.
Warning pressure washing can cause personal and property damage or death. ( BE CAREFUL ! )
.I pressure washed my driveway to have a clean surface to place boat cover.I put dirty side down wet it with water hose and laundry detergent then pressure wash (3000 psi washer) turn over pressure wash 2nd. side. It removed ALL the mold and most all the dirt, three 1/2 in. diameter spots remain (wine stains?).With no visible signs of damage to boat cover.
