??? IMAGE SHADOW CAT??? I need a history lesson please. >
Old 10-02-2012 | 03:25 PM
Registered User
Default ??? IMAGE, SHADOW CAT??? I need a history lesson please.
Newbie here. Although I've had large powerboats for the last 8-9 years this is my first Cat.
After doing a lot of research before buying this boat I found a bit of info. I was hoping someone here could inform me with some more history on this Cat.
What kind is it really?? I have had 10 different answers from ten different people haha
A few of you might have seen it for sale at DFW in TX was also on Ebay for a while.
Its a 1988 Image ( per the title & vin plate ) advertised as a Shadow cat. 31ft long.
Said to belong to a team bandit racing & or Scott Manders *sp*
Seems to have no expenses spared when build back when.
Marine Machine hydraulic steering, k planes, W.P. Engines, Livorsi marine throughout the boat, super nice all aluminum trailer.
Looks like it was once painted yellow with purple accent color.
If you know anything regarding this boat ( good or bad ) please let me know, just curious really any pics, vid's, or just general info would be helpful !! thanks in advance......Mike
GTOKILLER is offline
Old 10-02-2012 | 03:51 PM
bill63's Avatar
Fast Priorty II Nor-Tech
That is a 31 image cat built in algonac michigan. The company is now call Ocean express they have a web site with a lot of old pictures. There were a few bandit named image/express cats back in the day 31 yellow was a outboard version raced by a guy out of ohio. There was also one called Baja Bandit wich was yellow but I believe that was the 33 model. There is no affiliation with shadow cat completly different boat.
bill63 is offline
Old 10-02-2012 | 03:52 PM
Registered User
I bought this boat knowing it had a bad Port engine. Turned out to just be a bent valve from the marinas mechanic trying to adjust them. Probably didn't know its a solid lift full roller motor. opps!! oh well there loss. I pull the engine assuming it was a rod knock of to find nothing. I sent the heads out to be rebuild, put it all back together it runs great!! held 7200 RPM's across our small local lake about 4 times.
Has World blocks & heads, 377c.i., JE pistons, balanced & lightened crank, full roller, all crane valve components, Dooley 8 qt. pan W kickout & trap doors, MSD ing. W/ limiters , Stainless marine headers, Edelbrock RPM intake, holly 850 CFM 30cc primary 50cc sec.
Seems to be very put together set of twin SBC's
I will know in in Dec. both are bing pulled back out, freshened up & run on a dyno
Old 10-02-2012 | 03:53 PM
Ran-Dom 32's Avatar
looks more like an Ocean Express 33 to me I think Image had something to do with OE & Awesome at one time or another
Ran-Dom 32 is offline
Old 10-02-2012 | 03:59 PM
Registered User
Thank you! I talked to Ross a few years back (07) about a new cat. At the time I was setting a little better financually. Instead I ended up with a fixer-upper haha. Kinda cool I ended up with almost the same boat builder just a couple decades earlier.
This has a "Team Bandit Racing" sticker on the scoops just thought it might help identify who it belonged to!
Old 10-02-2012 | 04:05 PM
bill63's Avatar
It went.. active cat/image marine/express marine/ocean express.They built a few under the baja name during the image years. Awesome was never affiliatied with Ross Focht
bill63 is offline
Old 10-02-2012 | 04:09 PM
Registered User
That seems correct, Ross showed me some pics of the Cat's be build for Baja. Also did not speak very highly of Awesome.
Old 10-02-2012 | 04:10 PM
bill63's Avatar
Does it look like it could of had a bracket for outboard on the back.
bill63 is offline
Old 10-02-2012 | 04:16 PM
h2oboater's Avatar
Here is a little history lesson on Ross cat's.
http://www.offshoreonly.com/forums/o...assifieds.html
And a Klym cat read here.
http://www.offshoreonly.com/forums/a...ride-hell.html
h2oboater is offline
An original shadow
prostock85 is offline
