Prop Slip
Old 10-03-2012 | 06:57 PM
Rottiguy's Avatar
Default Prop Slip
01 36 Spectre
38 pitch 5 blade Herings
-2 imco shorties
Neutral Imco boxes
1.35 gears
6000 rpm 126 MPH
So wheres the problem? Should I try some spacers? Or loose the boxes? I'm thinking spacers cause I throw a mean rooster tail. Ive cracked 2 sets of props so far.
http://youtu.be/tvUv2v4ssPA
Rottiguy is offline
Old 10-03-2012 | 08:32 PM
IMO the quickest and least expensive place to start would be to add a 1 inch spacers and try it, it will at least give you some usable information to start with. The video was Sweet but the tail looks very similar to mine. I run a 32 pitch at 6200 with 1.36 gears 11% slip on a 38 Ft cat. But I believe you need more water on the blades. I'm not an expert just my thought, assuming you are not running to much trim, and the rooster suggests no over trimming, I found my cat is most efficent at zero trim but each boat has it's own personality. Good luck, keep us posted.
abones is offline
Old 10-06-2012 | 11:41 PM
Boater8987's Avatar
Airking
2002 Spectre 36' Pokerun 600SCI. 1.35 36P bravo box stock props. 5800RPM on limiters. Has -2 sportmasters with 2" spacer back to standard length. No boxes. First time out with new motors. Have had boat several years previous motors 575SCI. I have cracked, broke and thrown multiple labbed sets of props over the years. No problems with box stock bravo's for the last couple of years. Except for the ones I loose to broken prop shafts and debris strikes.
Boater8987 is offline
Old 10-07-2012 | 07:07 AM
Rottiguy's Avatar
So it looks like I need to hunt down some spacers, and if that doesnt work, remove the boxes.
Rottiguy is offline
Old 10-07-2012 | 08:36 AM
Rottiguy's Avatar
21% slip is a ton. I may need to find a set of 6 blades I guess. x is 2" above the bottom
Originally Posted by riverrat
http://www.mercuryracing.com/propell...calculator.php
could be your props,trim, whats your X dim ?
Jeff
Rottiguy is offline
