Re-drilling Mercury Headers for 525, 600 to fit standard bolt patern >
Old 10-05-2012 | 06:29 AM
F-2 Speedy's Avatar
Default Re-drilling Mercury Headers for 525, 600 to fit standard bolt patern
Anybody done it, is there a template out there, Going to be running AFR's on my rebuild, I found some headers off a 600, wondering how big of a pain in the A$$ it would be to redrill them to fit, I was told the two outside bolts line up but the others dont, is that correct. Or should I keep looking.
F-2 Speedy is offline
Old 10-05-2012 | 06:32 AM
yes that is correct .i think its 3/8 ths diff .i use a gasket as a template simple job .go easy drilling though its stainless
smokin' gun is offline
Old 10-05-2012 | 09:05 AM
C_Spray's Avatar
Diamond Member #001
...I'd suggest welding up the old holes first, then drilling.
C_Spray is offline
Old 10-05-2012 | 03:35 PM
Default fixx
check with afr first to see if they can drill the head whyle its in the cnc..
FIXX is offline
Old 10-05-2012 | 04:40 PM
just bolt down the two outer holes and call it good!
keegan is offline
Old 10-05-2012 | 05:50 PM
F-2 Speedy's Avatar
funny guy, how ya been
Old 10-05-2012 | 06:45 PM
Default fixx
Originally Posted by riverrat
what if he ever wants to sell the heads , or has to change one due to catastrophic failure ? could be a cluster f
Jeff
what if the header fails and he has to do it all over again...lots of what if's..me personally i wouldn't even consider a cmi header..stelling is out and the only other option woulf be lightening or hardin ..those two are made alot better then cmi...i have a customer that i installed a set of lightenings 12 yrs ago and their still mint and the outer pipe in steel..got friends with cmi's and they all heve been sent back and they still had problems with them cracking or leaking at the welds..
just my o2..
FIXX is offline
