Lucas Oil Treatment
Old 10-08-2012 | 01:22 PM
97FASTech's Avatar
Veteran: Army
Default Lucas Oil Treatment
Going to run a quart of Lucas oil treatment next oil change with Mobile 1 15 - 50 this time. Anyone else running Lucas oil treatment? Pro's or con's.
97FASTech is offline
Old 10-08-2012 | 07:49 PM
Why????
Griff is offline
Old 10-08-2012 | 07:58 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I run it in everything. It's been good for me. There are past threads on this topic.
Sydwayz is offline
Old 10-08-2012 | 08:19 PM
i used to use it in my 05 f250 with the 6.0L desiel for a while,lucas sais up 2 20 percent,but after a while i quit ,for me,i cant see any real need for it,if you change your oil&filter often,as i do,the oil stabilizer is really a waste of money,but some people get peace of mind by useing it.i cant see where it can hurt anything useing it,other than a few xtra bucks at oil change time.
mike tkach is offline
Old 10-08-2012 | 09:24 PM
i buy it buy the gallon and use it in everything..i see better oil pressure in the boat with 15w50 M1..after a hard run i use to drop down to 15 psi at idle with out it,,same run with lucas i see 25 psi at idle..
FIXX is offline
Old 10-09-2012 | 07:25 AM
CIG3's Avatar
I run it as well. Pulled a motor apart a few months ago that had 300 hours and bearings looked brand new. I started running the Lucas in it after 10 hours of break in.
CIG3 is offline
Old 10-09-2012 | 09:32 AM
97FASTech's Avatar
Veteran: Army
Read some previous threads/posts, just wanted something more organized for next search. The best titled thread had only 3 posts. Had to read many others to find answers.
This is the exact reason I wanted to try it.
Seems there are some for it, and some say it does not help at all.
Thank you all for the comments.
Old 10-09-2012 | 01:30 PM
berns29scarab's Avatar
i use all of there products in cars, boats, bikes, trucks etc... engine oil stabilizer, trans, power steering fluid conditioner etc...
berns29scarab is offline
Old 10-09-2012 | 01:47 PM
never mind
Back4More is offline
