What's the Best Method of Removing Old Registration #'s from Hull? >
Old 10-09-2012 | 05:35 PM
Default What's the Best Method of Removing Old Registration #'s from Hull?
I bought a new to me boat from out of state and will have to change the registration number. What is the safest/best way to remove the letters from the hull? Heat gun? Goof off? Let me know what worked best for you...thanks.
Scabby Jack is offline
Old 10-09-2012 | 05:39 PM
Rubbing alcohol will work, it's slow but doesn't hurt anything.
mean streak is offline
Old 10-09-2012 | 06:01 PM
CNC's Avatar
CNC
I use my wife's hair dryer, with a plastic window ice scraper. A heat gun is to hot.
CNC is offline
Old 10-09-2012 | 06:04 PM
3M Eraser wheel. You can buy one at your local body shop supply place.
VCMike is offline
Old 10-09-2012 | 06:05 PM
lucky strike's Avatar
Acetone
lucky strike is offline
Old 10-09-2012 | 06:29 PM
I've got some options now...4 posts with 4 different techniques to try.
Old 10-09-2012 | 06:36 PM
Offshoreonly Advertiser
Default Number removal
Bring it to New York !
sy goldberg is offline
Goo gone might work?
Greatguy66 is offline
Old 10-09-2012 | 06:44 PM
Too Stroked's Avatar
If the numbers are self adhesive and the hull is straight gelcoat, heat them up with a hair drier and peel them off. Any remaining adhesive can be removed with Acetone. If the hull is painted, you can still use the hair drier, but use citrus cleaner to remove the adhesive.
If the numbers are painted on, use Easy Off Oven Cleaner.
Too Stroked is offline
Panther's Avatar
Frank's Marine Service
Are they vinyl? If so, a little heat and a scraper to get the edge up then heat and peel. Acetone for the remaining residue and some wax afterwards.
Panther is offline
