CMI header mounting hardware
My CMI headers on my AT are just bolted with the standard header bolts. They do rust some, but have stayed tight for the 5+ years I've owned it.
On My Pantera, I used the ARP stainless header studs and nuts. They looked much better and stayed tight as well.
Problem with studs and nuts is getting them on and off in tight engine bays. With the socket head cap screws (Allen) bolts a ball end Allen socket can get on every bolt and with my e-tops I had on my hawk I could get at every bolt with a dewalt cordless impact.
Sounds like a good idea. Probably a bit cheaper than ARP too....
I think spec is 30 or 35 #'s, but I never actually used a torque wrench. There just is not room on most of them. Just snug them up tight with using a normal length 3/8 ratchet or wrench.
allen head's a good idea, I just thought it would be easier with studs cuz you could hang the gasket on the studs and place the header on, and tighten, Im a new-bi to headers on a boat, installing some on my rebuilds this winter.
