Someone to braze/tig weld a pickup tube >
Old 10-11-2012 | 08:14 AM
Default Someone to braze/tig weld a pickup tube
I'm replacing the oil pump on my 502 during a rebuild and would like to get the new pickup brazed/tig welded to the pump. The first attempt didn't work so I would like to get someone that knows what they are doing so it stays in place. Let me know if you can help.
Thanks!
jvcobra is offline
Old 10-11-2012 | 08:25 AM
I can weld or silver solder the tube in place. You would need to mark and or have the tube in place. I am located in Detroit so it may not be worth shipping this far.
Jeff
313-410-1367 6am-8pm
sbslinde is offline
Old 10-11-2012 | 08:31 AM
The tube will be installed and marked, shipping shouldn't be a problem. PM me a price.
jvcobra is offline
Old 10-11-2012 | 09:08 AM
t500hps's Avatar
21 and 42 footers
Last engine I had put together (buddies helping me) theywelding machine he had was loaned out so I went to a local muffler shop, walked in the back door, handed the guy a $20 and told him what I needed. 10 minutes later we were leaving.
This was also being done because the first guy didn't do it properly.
t500hps is offline
Old 10-11-2012 | 11:47 AM
Fenderjack's Avatar
Pirate of the Chesapeake
You can just mig it on.do not need tig and don't brave the heat from the torch might warp the plate.Takes about 5 min.JOHN SR
Fenderjack is offline
