Bottom paint removal & gel coat repair (pics)
I just picked up a '97 Baja hammer that had bottom paint from '98. The previous owner started to take it off now this is what I'm left with. Whats my best bet to remove it completely? Also what should i use to patch the small holes in the gel coat? Thanks!
Yea, i agree it may be to far along to blast. Blasting adds a bunch of work on its own anyway. I would first try easy off oven cleaner. Let it soak then try a green pot scrubber type scotchbrite. That should get a good part of it off, from there maybe a thinner soaked rag to cut the light stuff.
08 OPA High Points Champion
It had about 7 years of paint and it was primed .I scraped most of the paint off with a paint scraper and alot of blades than I had to da the primer off with 600 grit buffed it. The transom I used aircraft stripper . Not a fun job.
